ConnectCADChecking the drawing
Command
Workspace: Path
Check Drawing
Design Suite: Entertainment > ConnectCAD Drawing
Spotlight: Spotlight > ConnectCAD Drawing
ConnectCAD: ConnectCAD > Drawing
Document context menu
Vectorworks can automatically check the drawing (the current layer or all layers) for problems with sockets, circuits, devices, signals, and layout objects. Any issues can be color coded for easy identification.
To check the drawing:
Select the command.
The Check Drawing dialog box opens.
Parameter
Description
Sockets
Checks for duplicate socket names and duplicate instances of jackfield holes
Devices
Checks for duplicate device names
Circuits
Checks for duplicate circuit names and deleted or moved circuits
Signals
Verifies whether the signal type is the same between the connector types
Layout objects
Checks for duplicate rack layout object names
Cable paths
Checks for cable paths that are not connected
Check Items on
Select whether to check only the active layer, or all of the layers in the file
Select the drawing items to check and the color for the issue markup, and click OK.
When tracking down a problem, it's helpful to avoid repeating tasks which passed successfully; deselect those.
Drawing objects with problems are selected, and marked up with a special class to make them more visible. In some cases, additional drawing objects mark specific areas. Resolve the issues, clear the markup, and run the Check Drawing command again to verify.
Check Drawing
Clearing drawing markup
Command
Workspace: Path
Clear Markup
After running a drawing check (or the Compare Cable List and Drawing command) and resolving problem areas or determining that they are not an issue for the current schematic drawing, the highlighted markup can be removed.
To remove markup after a drawing check:
Select the command.
Comparing the cable list and the drawing circuits
Analyzing cable paths
Placing devices
Connecting sockets
ConnectCAD
